Hi guys,
A question about windows 7 recovery disc Toshiba. What is the difference of windows 7 recovery disc application in Toshiba laptop to other laptop brands such as Sony Vaio, Compaq Hp Presario, Acer, Lenovo and etc.? Does they have similarities and differences? I just want to be aware.
Expecting some help, thank you.
Windows 7 recovery disc for Toshiba can only be used in toshiba. Recovery disc image when created, it creates recovery for software part (windows 7 in this case) and it will create recovery for hardware drivers as well.
Windows 7 recovery disc Toshiba hence cannot be used in HP, Dell, Sony and vice versa.
Shovon
Yes, there are some differences between windows 7 recovery disc of Toshiba and other brands.Although they might have the same operating system but different brand comes with some preloaded features/software's.These features/software's depend on the laptop's specification too.
The only similarity you might find between two different brands laptop is that they might have the same OS (i.e. Windows 7 Home Premium) and that OS's basic features.So, you should be aware of that and keep your recovery disk safe.
zeonx
Equation:
1. Using the same operating system is Windows 7
2. Used for recovery hardware drivers and documents in a laptop
Differences:
Although it has the same operating system, but the Toshiba recovery disk can only be used in a Toshiba laptop with the appropriate operating system. So the Toshiba recovery disk can not be used for any other laptop brands.
