Hi everyone, I have a new active directory at present that is why I also have to reconfigure my domain. In the start, as I do "ipconfig", I encounter a dns suffix, which could mean that I am in another domain. My question is, will it create issues later on as I still have a connection with that other network and I have installed another domain? Thanks for the input.
Question on creating active directory
Dear,
I have read your problem and have best solution for you.
Well you have asked an intelligent question as far concern to having two domains it doesn’t difference on you. At one time you have to select only one to have domain. One time you select the system you will be in that system domain.
You are trying to remain in both system domains in one time. But this can’t possible any way.
At one time one will be your administrator and you will be its domain.
Hope you got the answer.
Best of luck for your future.
