Question on ERP and CRM setup
I have separate client/server and software set up for my service ERP (Enterprise Resource Planning) systems, how can I know if the CRM (Customer Relationship Management) can be part of the ERP system?
Hello Stacey,
Enterprise Resource Planning will always be part of Customer Relationship Managementven if you have separate client/server. They are very similar with each other but they have different purposes. These applications allows you to coordinate and share information of an organization. An effective CRM requires ERM. You should be more broad with your question so that I can proovide you with more information regarding Customer Relationship Management and Enterprise Resource Planning. But I hope I enlighten you with this solution and it gives you an idea on how to solve your issue regarding CRM and ERM . Have a good day!
Zorian
Notifications
