A question on how can resize mp4 video.
Hello fellows,
A question on how can resize mp4 video. I got twelve mp4 videos stored in my laptop and me and my project group mates are having some difficulty on researching for the best software needed. We only have one week to prepare for this and we really need some help. I hope you can give some advice.
Curtis Marry.
Best Answer by Elliottsims
Answered By 0 points N/A #185865
Hello Curtis,
I recommend you to download Wondershare Video Converter. This software can convert and resize video files in just one click. It is user friendly and easy to use. Just put the video on it set the settings that you want, pick an output folder and convert. I use this software a lot to convert movies to transfer in my mobile phone. You can download it here http://download.cnet.com/Wondershare-Video-Converter-Pro/3000-2194_4-10689779.html . Hope I help you with your problem. Good luck on your project.
Answered By 10 points N/A #185866
Hi Curtis Marry,
Your problem is to how re-size your MP4 videos here is http://mp4-converter.info this link is for window Version. It can enable you to re-size while maintaining relatively high visual quality. This shows you how to re-size MP4 videos step by step. Just open the link and follow the instructions below.
You can try this http://mp4-converter.info/
Thank you for your question. I hope I gave you some help with that matter.
