rogermatt
10 points
Posted on - 07/28/2011
Hi there,
Next year I am going to University to study a BA in Photography. I am looking to buy a laptop, and I am set on getting Apple.
As I will be doing quite graphic editing, I need help on what MacBook I should choose.
I would really like the 15″ MacBook Pro. Is the standard 13″ MacBook suitable for what I need it for? Would I be spending an extra £300 or so just for bigger screens?
I would really like some advice, I’m hoping to buy it in December around Christmas and want to start planning on what I need.
Thanks,
A question regarding Apple Macbooks.?
As you have mentioned that you want to buy a Mac for photography editing and for you photography purpose. I guess the world of Photography has no bounds and so it should be and is done in different places. As you will travel first of all buying a laptop is a good option. Secondly you will have to travel and carry your laptop everywhere. So I guess you should go for 13'' standard display as it is not too small and will be easy to carry and comparatively light in weight with no compromise in the screen quality just that the size will be a bit small.
Cheers 🙂
