Regarding the much talked about "edged screen" on the Galaxy Note Edge, are all the useful and popular apps on play store compatible with the edge and its interface? Also, I root and install custom ROMs on all my smartphones and I love tinkering around with them. So I was wondering if all the popular custom ROMs like CM and all are compatible with the edge? Are they optimised to work with the edge?
Question regarding custom ROMs and apps on Galaxy Note Edge
No, every custom rom cannot be installed on your phone. You need to find the only roms that are compatible with your device. And if you get success to install the custom rom that is not compatible with your device it will not work well. And also main thing custom rom also ends the warranty of your device mainly it is mentioned on every web.
That’s right. Not all customized ROM is compatible with every Android Smartphone and it is not wise to install a custom ROM especially on a brand new Samsung Galaxy Note Edge. Also, custom ROM has specifications which indicate to which Smartphone model it can only be installed to. Samsung Galaxy Note Edge operates on GSM, HSPA, and LTE networks [2G, 3G, and 4G] and uses a micro-SIM card.
It was unveiled on September 2014 and released on November 2014. It measures 151.3 x 82.4 x 8.3 millimeters and weighs 174 grams. It has super AMOLED capacitive touchscreen display with 16M colors at 1600 x 2560 pixels screen resolution. It is protected by Corning Gorilla Glass 3 with curved edge screen and supports multi-touch.
It runs on Android 4.4.4 KitKat powered by Qualcomm Snapdragon 805 chipset, Quad Core 2.7 GHz Krait 450 CPU, and Adreno 420 GPU. It runs on 3 GB RAM and available in 32 GB and 64 GB internal storage capacities. It supports microSD that can be expanded up to 128 GB.
The primary camera supports 16 megapixels at 3456 x 4608 pixels resolution with optical image stabilization, LED flash, and autofocus. It features geo-tagging, Dual Shot, simultaneous HD video and image recording, panorama, HDR, touch focus, and face and smile detection. It can record video in 2160p at 30 fps, 1080p at 60 fps, and 720p at 120 fps with optical stabilization and dual-video recording.
The secondary camera supports 3.7 megapixels and can record video in 1440p at 30 fps. It has Wi-Fi 802.11 a/b/g/n/ac with dual-band, Wi-Fi Direct, and hotspot. It supports Bluetooth 4.1 with A2DP, EDR, and LE as well as GPS with A-GPS, GLONASS, and Beidou. It has NFC and microUSB 2.0 with MHL 3 TV-out and USB Host.
It has accelerometer, SpO2, gyro, heart rate, proximity, UV, compass, and barometer sensors. The built-in browser supports HTML5 including Java. It runs on Li-Ion 3000 mAh battery with talk time up to 18 hours on 3G.
