stevewaugh
30 points
Posted on - 07/28/2011
How is it possible that the program is a Visual Basic 2008 for free download from Microsoft's site .. And then be surprised that requires Serial otherwise it will work for 30 days.
Can anybody help me out to solve the problem as soon as possible.
Steve Waugh
Question regarding serial visual basic 2008
Hi ,
i have read your post its not a big issue to resolve.
Actually Visual basic express 2008 will only comes with the validity of 30 days, it will expire after this time span. But if you want to use it for unlimited time then you need to get registered. But in my opinion i recommend you to use Visual basic express 2010. Because it's totally a new and more modified version and after using this i am sure you will no further find any problems with this application and 1 most important thing is that don't forget to register as well. Try to register to overcome this problem.
Hope my solution will help you and you are able to work with that again with no further anymore problems…
