Question regarding virtual server ?
Firstly, I would like to check if Virtual Server 2005 SP1 can runs 64 bit virtual machine on the 32 bits host system?
Secondly, I have tried to create Windows Server enterprise 64 bit virtual machine using Virtual Server 2005 SP1 but it keeps prompting the hardware CPU does not support. I'm using a 64 bit OS to run the virtual software.
Lastly, what is the difference between virtual server and virtual pc?
Thanks,
