Question for slow speed using DVD ROM
I use Samsung DVD writer, When I insert disc into it, it takes a long time to read and write. If I set it another computer this problem is vanished. Why this situation arise and how can I solve this problem?
As far as I know you have a sufficient memory but you are running in a fast CPU. Well, it’s not in the top of the line but Samsung DVD writer is a good quality peripheral and most the users regards it positively. Two areas that you might want to explore is by checking for a new XP drivers and DMA support. Even though these drive is compatible with XP, but some suggestions that XP support is just adequate, try checking out some update drivers. With the Direct Memory Access right click on the My Computer then Properties, then device manager and select the DVD-ROM and click the properties. One of these tabs you will find the DMA option and try to check if it correctly set.
Well i there are many factors that may affect the performance to the Optical drive u have use…it may that u have in sufficient memory or it could also be the hardware u are using is not compatible to the operating system being used in the Computer System Unit.
Notifications
