Questions regarding Virtual Machine errors
Hi experts,
I got the some queries regarding test complete installed on 10 VM machines.
Is it good to develop test scripts using Virtual Machines?
Virtual Machines have a break point. Recently, it reached its break point as I debug.
However, the screen frozen and needed a restart after I deleted the test complete. exe file.
The error message looks like this:
Errror – AD FS 2.0 Management
An error occurred during an attempt to read the federation metadata. Verify that the specified URL or host
name is a valid federation metadata endpoint.
Verify your proxy server setting. For more information about how to verify your proxy server setting, see
the AD FS 2.0 Troubleshooting Guide (https://technet.microsoft.com/en-us/library/adfs2-troubleshooting-guide(WS.10).aspx).
Error message: The remote server returned an error: (403) Forbidden.
Lastly, do I need to input username and password in Virtual Machines when using Network Suite?
I keep receiving an error message saying "Error-AD fs2.0 Management. An Error Occurred during an attempt to read the federation metadata. Verify that the special URL or host is valid. Federation data endpoint."
Any help is highly appreciated.
Answered By 0 points N/A #107188
There are some certificates named as Token Signing and Token Decrypting cause this type of errors. If you reinstall the ADFS tool the problem still stand. So to solve the problem you had to install it into the Trusted Root Certification Authorities store. After installing it your error should be gone and may you receive some warning saying that the certificate you have provided is not trusted by the trusts provider.
Another work you have to done:
You have to open the Manage tool. For doing that right click on your computer icon and click on manage. Double click on the Groups which is in console tree. After doing this you have to verify your account name which appears in the member list. For this you have to double click on Administrators
