jeangreen
Posted on - 08/09/2011
While I was using the Quickbooks application, it stopped working and displayed the error message below. I am wondering what might be the cause of this error message. I do not remember changing any settings on my application.
Please help me fix this error. Thanks a lot.
Microsoft .NET FrameworK
An unhandled exception has occurred in your application. Â If you click Continue, the application will ignore this error and attempt to continue. Â If you click Quit, the application will be shut down immediately.
This application is not allowed to log into this QuickBooks company date file automatically. Â The QuickBooks administrator can grant permission for automatic login through the Integrated Application preferences.
Details                               Continue                 Quit
Quick Books encountered a network problem
Have you recently made any changes on your computer?
Have you recently used any third party registry fixes or updates?
It could be a virus, so run a Malware/virus scan on your computer. You can run it online or by using a software.Â
Please select the link of your choice.
If the issue remains, try running your computer in safe mode. To do that, follow these steps:
Reboot your computer then press F8 and select the 'safe mode' from Windows Advanced Options menu.
You could also try a 'clean boot' to make sure that this issue is not caused by a conflicting background program. To do this:
Click the start button ; then in the search box, type msconfig ; then Enter. In General Tab, just click Selective start-up ; in selective startup clear the load startup items check box.
Also, in the services tab, select Hide all Microsoft services and disable all. Finally, restart your computer.
Hello Jean,
Based on the description that you have given, you may be getting that error for quite several reasons:
The issue might be caused by some application that you installed on your PC.
That kind of issue occurs when the format of an argument fails to meet the parameter specifications of the invoked method.
However, to focus on the possible cause of corrupted .NET Framework, you will need to try the Verification tool to verify .NET Frameworks on your machine.
If it has issues, you will need to perform a windows update so that the latest version of the .NET Framework will be downloaded and installed.
Hope this helps.
Carl
