Quick Cam Video Effects: not supported with selected camera resolution
I wanted to use a video effect in QuickCam, but it says that the effect isn’t supported with the selected resolution.
Is there a way to have that resolution acceptable for that video effect?
QuickCam
Video Effects are not supported with the selected camera resolution
Change resolution to continue using Video Effects.
Answered By 0 points N/A #160542
This problem is because by incompatible resolution you need to change the resolution of the camera to make the effects work; try changing the resolution of the QuickCam and check if any of the resolution you change works and fits.
–          Double-Click on the Logitech QuickCam icon on your desktop or right click on the icon in the taskbar.
–          Go to “Properties” select ”Stream Format” in the properties program.
–          Click on the “Output Size” there you can see all the possible setting of the Display resolution’s.
–          Choose the resolution that fits for the video effects.
You can also change the Contrast, Brightness, Saturation, and Hue of the camera in the setting
