Hello, My computer got stuck on the windows error recovery screen. Currently, I am working on windows 7. I am unable to open windows, safe mode, and I also have a windows 7 disc, but it doesn’t help either. Please help me solve this issue. Thanks
Quick Fix For Troubleshooting Windows Error Recovery Screen
Hi. Many times the issue might be in file system because we often switch off the system while it is in use. There are many ways to solve the issue. Choose which suits you the best.
a. We can download easy recovery essentials .after that, burn the image and follow the steps. Now boot your system and select automated repair. Later EasyRE will give details of its results. Then restart your PC.
b. Firstly restart the system and continuously click on f8 there comes a set of boot options, then choose the Last known good configuration (Advanced), press enter.
c. Connect your Windows CD, then click on any key to boot the disc and later press on repair your system and also select a folder or a drive then go for system restore. Finally, click on the finish.
d. Connect your disk, then restart your system later, click on any key to make the cd boot then press R to view a recovery console page and give your admin password and type chkdsk C: /f /X /r. Later restart your system. If you need more details don’t hesitate to contact us.
