Quick Look- A Preview Software Like MacOS
I usually click a lot of pictures daily. Some of them are unwanted. So I have to open every photo on my pc and then delete it. Can you suggest something that might make my work easier?
Answered By 0 points N/A #324585
Quick Look helps you to preview your items on your laptop with Windows installed on it just like MacOS. It is absolutely free and very easy to use. It is a simple application that helps you to get a preview by just clicking the space button. It is easy and handy also. It has no additional tolls with it.
