Quick screen capture software questions
HELLO !
I have some questions about Quick screen capture software which are as follows :
1. How do i make a screenshot ?
2. What is windows object ?
3. Can it capture direct X mode games ?
HELLO !
Dear Floyed Brice,
There are many capturing tools available on internet for free download.
These capturing tools are used to capture a still from any video, game or other things.
Capturing tools are of two types.
1. Snapshot capturing.
This will take only snapshots of the desired screen. You can edit the snapshot as you want.
2. Screen Recording.
Recording Software provides screen recording facility. Screen recording tool will enable you to capture video of whole screen.
Your question is, how do you can make screen?
So dear, I will suggest you to try windows own capturing system.
Press the “Print Screen” button on Keyboard at specific display that you want to capture.
Now open Microsoft paint or any photo editing software. Right click and paste.
It will place your captured snap here. Now you can edit this snap as you want. You can use it for many purposes.
You can capture the snap of DirectX Game also. Procedure is the same.
I hope it will help you.
Thanks
