Quick Transmission of Large Files
What application can you suggest in transmitting large files or program information to people in other countries that saves time?
Hello Jessica Grant,
There are a lot of services that you can avail in order for you to send and received large files online. You can use Pando 2.3; it allows you to send and receive any type of file up to 50 GB with 1 GB free. It could be integrated into different email provider Gmail, Hotmail, Yahoo! Mail, AIM Mail, even Outlook and Yahoo! Messenger.
However it can only be used in Windows and Mac operating system. You can also choose SendThisFile; it offers a free service by sending large file but the paid service allows both sending and receiving. There is no limit on the file size that you will be sending however it does not scan files for viruses. Another is Podmailing 0.10; however it does not integrate with email software directly.
Atanasosk Pelayo
Hi Jessica Grant,
Transferring large files is a bit of a time consuming task, until you find a good service for it. The best service for transferring large files is Drop Box, it is free for up to 5 GB of use, but after 5 GB you will have to buy a premium membership. It is the best service I have ever used. If you want a free service, then you should definitely go with Team Viewer, which is another great service for transferring files and sharing screens. Thanks and best of luck.
