dinacallway
1220 points
Posted on - 07/26/2011
Hi, posting herewith an error message screen shot that I meet when I am installing .net as a third party software for my Quickbooks, I installed .net on my system since it is a requirement on one of the features of Quickbooks.
Error Installing.NET 1.1
(error;1603) There was a problem installing “Microsoft.NET Framework 1.1”,
Note the error number and type this in a Web browser
https://quickbooks.intuit.com/learn-support/
During my installation of .net the above screen shot appeared on my screen, I keep on trying to install .net again and again, even getting a new copy of .net is already been tried, but same error message appeared, I am already run of ideas on solving this issue,
Please help me solve this error message,
Thanks a lot.
kevin11
QuickBooks Error Installing .NET 1.1
Had you checked the installation requirements for .NET?
Is it compatible for that or not. Is this okay then there might be some file corrupt of .NET which is causing the failure of installation. But as you said that you also tried from another source and same problem is there.
Then there might be a problem with windows files. Maybe some files are corrupt or there is some kind of virus inside your system.
First get there good and registered Anti-virus and scan your computer and then try to download it from the good or official website and also make sure the version is fully updated.
When you download the .NET then go to
Start>Control Panel > Add/Remove and remove the previous .NET or replace it with newer one.
And then restart your system and reinstall the downloaded .NET. If there is a trouble then you restart your PC and go to safe mode instead of normal mode and install it there.
That won't be a problem.
Hope is works.
Have a Good Day Dinacallway!!
