QuickBooks invoice sending error message
My problem is related to QuickBooks, e-mailing my invoice to be precise.
When I try to do it an error message is displayed:
QuickBooks PDF Converter Activation Error – 20
You cannot print directly to the QuickBooks PDF Converter.
Try using QuickBooks PDF Save as PDF menu option.
OK
I would be very grateful if you could help me by sending a solution quickly because I’ll need it very soon. Thank you.
