Hi, I was a Quicken 2009 user who upgraded to 2012 version. I am the owner of a Financial institution and the transactions are not updated in a single step. I tried to deactivate the account as recommended by another post, but that too didn’t work out. I have downloaded my transactions from the Amplify site, but I’m unable to use the current version of Quicken.
Please help me by giving instructions to disable and enable this account so that it works with Amplify Credit Union.
Quicken 2012 Does Not Work With Amplify Credit Union
Actually you cannot do this. The reason is that the transactions that are associated with one account will be affected if you do this type of thing. So in order to de activate the account, you need to be sure that the transactions will no longer be needed.
In order to do this you need to see if the transactions are required at any place. If so then make a list of all such transactions and set them aside.
Apart from that, you need to make sure that the account you are about to de activate does not have to do anything with any other account since I don’t know the complexity of the accounting system you have.
