Quicken on Win 7, 32bit need help
Can't seem to install on my HP with win7,32bit. I get errors that quicken didn't help with their boot download.
You did not add in your post the version of Quicken that you are using. Try upgrading your current version to Quicken Home & Business 2012.
This version of Quicken can be installed on a computer running on Windows XP Service Pack 2 or higher, Windows Vista, or Windows 7 both 32-bit and 64-bit versions of these platforms.
You must have at least a Pentium processor with 1 GHz speed. This version requires 1 GB of RAM installed on your CPU. Other components that are required by the application like Microsoft .NET Framework 2.0, and Windows Installer 3.1 are all included in the Quicken Home & Business 2012 installer.
If you require additional information regarding this version of Quicken, visit https://www.quicken.com/.
Notifications
