Quran jar mobile apps for my mobile
Dear Friends,
I would like to have Quran jar mobile apps for my mobile. Please advise, where to get it at free of cost [if the free version is not available, I am ready to pay]. If you can provide me the online provider's web address, that will help me a lot.
Thanks in Advance.
David
Best Answer by Ford Smithkings
Answered By 0 points N/A #156162
Hi
You can find the Quran java application that is compatible with your phone from either one of the following sites.
Answered By 1065 points N/A #156163
I’ve been using Zedge for a long time when it comes to my mobile needs. You can get free themes, apps, wallpapers, video and ringtones from there. Just sign up for an account and you can get them free. Remember to select your device so you can download files appropriate for your chosen device. You can also access Zedge directly from your mobile phone if you have an active data or Wi-Fi connection. ‘
You can also get free themes, apps, wallpapers, video and ringtones from Mobango. You also need to create your own account and access thousands of files for free. Here is a link to get free Quran:
https://www.mobango.com/quran/?cid=1273746
