anonymous
7060 points
Posted on - 03/11/2013
Hi Friends, Where should I get Quran reciter jar free apps for my mobile for free of cost. I need a software as that of  Quran reciter jar free Software that helps the mobile application. Please do the needful for sending me the link that will download the software. Thanks in advance
Hello my friend.
Here is the link for Quran Reciter for Mobile jar file. I hope that what you are looking for. Download and enjoy. Please give a feedback if ever the link does not work. I will update another link for you my friend. Do not forget to say thanks.
points
There are many softwares that can be found on Java version.
You can download TinyQuran. It is a small Quran reciting software that supports many nice features. It has got nice reciting option. You can configure to play same verse, continuous recitation or manual mode.
You can also select the range of verses to be recited.
