Rabbit folder icons windows 7
Good day techyv!
I was having a problem making rabbit folder icons windows 7 operating system. Please provide me step-by-step procedures with pictures in changing windows 7 folder icons to rabbit icons.
Good day techyv!
If you are looking for rabbit icons for your folders, you don't have to make it yourself. There are many rabbit icon sets that can be found in the Internet. Here is one set to help you get started. For customizing your folders to use these icons, this guide can help you do such.
Hi Daub,
Hope all is well with you today. I was able to get something that might help you out. What I am about to introduce to you is a simple tweak to change the folder Icon of your win 7. This is not the usual setting that you configure from your Windows. This as well won’t work with Home version of Win7. If this will work with your machine it will totally change the Icon of your folders. Here’s how:
Notes: replace “Folder.ico” with the filename of your file from “IconFile=Folder.ico” so it would look like “IconFile=myImage.bmp”.
Hope this helps!
