Hi there,
When I want to open Ragnarok Online 2 this error appears closes the game. This error appears after I have updated my Windows 7 and after the update I reinstalled the game. Now is not working at all. Can anyone help me please ? What could be the problem ?
Thanks !
RO2Client
String file not found.
Ragnarok Online 2 download and patch problems
Open your installation folder and right click the RO 2 client file.
Here you would see the option "run as administrator."
Click "run as administrator." Now it should work.Â
If it doesn't work. Find your installer files and remove the gravity folder.
Then download RangerOnline2-installer-fixed-msi. And put this file in the same folder having media cab files
Now double click the fixed file and and install it as earlier. And confirm there should not be a security error.Â
It would ask you to modify, repair or remove installation. Go with "remove"
