Rainlender was not able to refresh the setting correctly
I just installed Rainlender2 on my system and tried to refresh the settings on the startup but the following error message displayed. I also used the backed up version to resolve this issue but I could not get any resolution. How can I fix this issue? Is there any way to resolve the matter as soon as possible? I would be grateful to you. Thanks in advance.
Question… Rainleadar2
Rainlender was not able to refresh the setting correctly.
Do you want to reset all settings and try again Or use one of the backed up versions ?
