frank frank
Posted on - 07/18/2013
Rainmeter version is not supported error to install the skin higher version skin. Rainmeter is the best system-monitoring application let you to apply custom gadgets like skins in your desktop screen.
Rainmeter skin is easy to create but some downloaded skin required latest version, it gives windows version error.
Help me.
Thanks in advance.
Error:
Rainmeter 2.5.0.1792 or higher is required to install this package.
Get the latest version from rainmeter.net and try again.
Rainmeter supported version error when try to install
Hello Frank
RainMeter is actually a desktop customization tool. It has various skins that can be placed right on the desktop.
Please access the link below and read the Changes made in RainMeter 3.0 beta version. It has lots of improvements and it will allow you to install other skins.
The skins which you were trying to install is for a different version than the one you have. And this automatically needs an update in order to be solved.
RainMeter 3.0 beta Changes
Also I have provided you with the link from where you can download the newest version.
RainMeter 3.0 beta
I hope you will find this information useful.
Randolph
