Sawyer Z.
Posted on - 08/30/2011
While I was doing some benchmarks to see what score my PC receives, I took a look my RAM latency and the values where a little higher.Normally CAS# Latency, Ras# to CAS# Delay and Ras# percharge have all had values of 9. Now they all show values of 11. Is that normal ?
Does PC overclocking has to do with it ? I am afraid that they might break down in a few.
Thank you
RAM Error – Latency change over night
Nope, that is quite normal. You will see them overblown sometimes but that doesn't matter at all. They have to show values of 9 but they are showing values of 11. That's quite normal but sometimes it happens. CAS # latency always ahs to show value of anywhere between 7 to 10. And that's quite normal for it. I had one of my friend too getting these strange values but he started to use the computer normally with somewhat less usage. So, you too try to use it for somewaht less time and that would be good.
Cheers.
It doesn't matter much. Sometimes CPU Z can mess up things while showing benchmarks but there is nothing to worry about you can use other testing programs like Blackbox.
It also works the same as CPU Z you can check it out to see what values does it show.
You can get it from here https://winaudit.en.softonic.com/?ex=DSK-347.0.
I hope this helped.
Peter franklin
