RAM preview after effect problem
This is maybe because your computer is running on a lesser amount of RAM. If the program you are using to preview your RAM is displaying it more graphically, this might slow down the processing performance of your computer. And if your video card doesn’t have enough video RAM, this will add more processing task to your processor that might cause the sudden freezing.
If you are viewing your RAM while other applications are opened or running, close all applications except your RAM viewer. If this doesn’t help, restart your computer and then run your RAM viewer exclusively. This means after booting the computer run the RAM viewer and don’t open any other applications besides it.
You don’t necessarily need to install third-party RAM viewer because Microsoft Windows already has a built-in RAM viewer which you can view from the Windows Task Manager. Open Windows Task Manager by press CTRL + SHIFT + ESC then select Performance tab. It may also help if you increase the amount of virtual memory your computer has.
To learn how to properly configure your virtual memory, please refer to Windows Terminal Server Proxy.
Notifications
