Ramdisk installation error – Looking for Help
Hello to all,
I am using OS windows 7 x86 service pack. Recently I bought a Buffalo external ministration 3.0 drive for some of my very useful programs. But when I tried to install this external hard drive, a driver installation error occurred on the screen.
The screenshot of the error is attached below:
RAMDISK Utility
Buffalo RAMDISK Utility
Driver installation error.
OK
I uninstalled the drive and then tried to reinstall it again many times, but I was met with the same error every time.
What can be the possible reasons of the error?
Your guidance is required in this regard.
Waiting for your replies.
Regards.
Clinton
Best Answer by Sharath Reddy
Answered By 0 points N/A #140266
try right clicking, go in to properties an run this program in compatibility mode for windows 7 see if that works.
Answered By 590495 points N/A #140267
Since the external hard drive you have requires installing its software then the next to check is the software’s technical specifications. You should verify if the software you are installing is compatible with your operating system. You really won’t be able to install your external hard drive’s application if it is not compatible with your operating system.
Since most of the hardware device comes in a package, check the printed information on the box for the software’s system requirements. If this information is not available anywhere in the box, check the documents that came with the device inside the box. It’s possible that your installation is missing some components required by the software like for example, Microsoft .NET Framework. My sister has a Western Digital mobile hard drive and this program I mentioned is required before installing the hard drive’s software.
