Sometimes when I launch Microsoft Office Outlook 2007, I receive the error message below stating: “The Add-in “epamTools””
What could be the problem?
The Add-in “epamTools” (C:PROGRA~2new01new02EPAMTO~1.DLL) cannot be loaded and has been disabled by Outlook. Please contact the Add-in manufacturer for an update. If no update is available, please uninstall the Add-in.
points
Random Error on Office Outlook,
Dear Bernard, your problem has got easy solution, don’t worry.
It is an error message that is informing you that you have got incompatible add-in that has been installed for Outlook.
This should give you no trouble using Outlook. You have to just disable this add-in. And if you know which program has installed it, you should update the program with the latest version and your problem should have solved.
Go to Tools >> Trust Center>> Add-ins >> Manage. Make the add-in “epamTools” disabled and press “Go”.
Hope no more problem with Outlook.
