RapGet File Downloader failure problem
I have a problem when i use RapGet to download rapidshare files. Last night it was working fine, but then i tried to download some stuff today with it and this error came up. Any ideas?
RapidShare
Files are not online available
                              OK
Answered By 10 points N/A #129510
Hello Chris,
If the RapGet File Downloader has been working just fine until you got that error, you will need to check the following:
  • Make sure that when downloading the files your connection to the internet is active. You might be getting that error because you have a slow connection to the internet and therefore the application cannot be able to retrieve files from the remote server.
  • If you have other download managers on your computer that are currently running I will recommend that you turn them off for they may be taking a lot of bandwidth and therefore hindering the RapGet application from downloading the files successfully.
Hope this helps.
Carl
Answered By 590495 points N/A #325172
That problem can be with the version you are using. Try updating to the latest. Download the free version of Revo Uninstaller and install it. Once installed, start Revo then select RapGet among the applications and click “Uninstall”. Follow the normal uninstall process. When uninstall is complete, click “Scan” to scan your computer for any leftover files and delete everything it finds.
This removes everything the program created on your computer. When it is finished, exit Revo then download RapGet 1.41. It should work on any version of Microsoft Windows. If the problem continues, check your internet connection or the link if it is valid. If it is a multi-volume archive you are downloading, the problem may be with the individual files or their links.
