Rapid SQL for oracle or toad for oracle?
Hi Experts,
This question is particularly intended for database developers.Well I wana know, between Rapid SQL for oracle and toad for oracle, which one is better to use for developing and producing high quality SQL and PL/SQL codes for database applications?
Please suggest me out of the two mentioned tools which one should I go for?
Answered By 0 points N/A #185036
I would recommend Rapid SQL because, even though both Toad and RapidSQL offer developers the capability of coding, editing, and optimizing SQL statements, it is only Rapid SQL that could offer such features in a cross-platform environment. For example, the IDE of RapidSQL helps developers create, edit, deploy objects residing on MySQL, Sybase, Oracle, DB2, etc.
Hope it helps.
Best Regards,
Parisi
