Attempting to hit on, first, while the lunch box shows up, there are no images, just a tiny symbol with square, triangle, and circle indicating an image should be here.
After that, however I strike the launch command, it receives me via the security launch… pauses… and the following error message shows on screen:
Rappelz-nProtect
Err code[114]: Game Guard initialization error. <BR> try again after a reboot or close programs that are currently running.
Rappelz-nProtect Err code[114]: Game Guard initialization error
Hi there Thomas H Linquist,
Your problem could have a few possible solutions. Try following the next steps:
Restart your computer. Sometimes this error happens because the application didn't quit properly so there is some process hanging somewhere and restart will help.
Check your antivirus and spyware and temporarily disable them to check if they are not blocking the application.
Check for your OS updated. The software you're using requires the latest version of Windows security.
And the last thing to do is to check if your graphic card drivers and Windows DirectX are up to date.
Best regards,
Drake Vivian
