I have a Razer Naga Mouse on my desktop, as I use it mainly for gaming. However, recently I cannot double click with the left mouse button. This means that highlighting text or moving icons is becoming a daunting task. Is there anything I can do to fix the problem? Â
points
Razer Naga Mouse left button malfunctioning
Razer Naga is a super gaming mouse that supports many function at the same time. There might be some problem either with the driver or hardware or both so the mouse isn’t working perfectly.
First, make sure that the driver is installed correctly. Razer Synapse is the driver that enables all the function with Razer Naga and other gaming hardware developed by Razer. Download Razer Synapse. Uninstall the older installation and install the latest one.
If the driver doesn’t fix this issue, you might have problem with the hardware. If you have got warranty or guarantee, contact the dealer. Otherwise, you’ll have to get a new mouse to have all the functions working.
