Razor dynamic menu will not load in Mozilla
Hi Guys,
Why is the razor dynamic menu page that I created using MVC not loading using Mozilla Firefox?
Any idea what might cause the problem?
Thanks,
Mr. Chang
Hi Guys,
Thanks,
Mr. Chang
Hello Mr. Chang,
Let me inform you about MVC razor first, razor is an engine that simplifies coding or current syntax used in ASP.NET web pages, which means it is a product of Microsoft.
For your concern, I think you're not the only one who encounter this problem when you apply MVC razor dynamic menu page using Firefox as a web browser cause Firefox is always will be a standards compliant browser which means, there is no existing version of Mozilla Firefox will address this problem.
I suggest that it is better to use Internet Explorer cause it is more friendly and get more privileges when you use Microsoft products.
The most important aspect of troubleshooting errors and any problems that may occur on your code is to easily avoid them.
Server info helps diagnose tool that can give information about your web server and in your host’s page.Â
It can also help identify issues on the type of browser that you are using.
