Razor synapse doesn’t open problem
I have Razer Synapse on my system.
When I tried to open it Synapse doesn't open and shows any message like updating Razer Synapse.
What is the problem?
If you know the solutions help me please.
Hi Kaitlynnnatasha,
I think you are asking about Razer Synapse if is it then,
They'll work without any Razer drivers,but you'll need the Configuration:
Now it won't start up but you can still launch the program if you ever need it.
From your description I become to know that you faced some sort of problems when you open razor synapse. I think it happens for some technical problems.
I think there have some installation problem or else. At this stage you can remove the previous installed file and you can download the updated version from here.
After remove the previous version please use c cleaner to fix the past issues clean up and must restart the pc.
I think your problem will solved soon.
