joan d vogt
10 points
Posted on - 02/07/2013
Hello Experts,
When I try to import my stall by clicking on food bottom it tries to open all of a sudden a message pops up and It Says Roller Coaster Tycoon 3 Has Stopped Working.
RollerCoaster Tycoon 3 has stopped working
Windows can check online for a solution to the problem.
Check online for a solution and close the program
Close the program
Thank you very much.
RCT3 Crashes When I install My Stall
Dear Joan D Vogt,
It's a common problem for all of the Windows 7 users. It's happening because your operating system is not installed properly.
You have to reinstall it properly, and you have to keep in mind that you have to install the perfect operating system for your PC. If your system requires a 64bit operating system, you have to install it or a 32bit system.
Thank you,
Lesliez Mark
