tymoore
10 points
Posted on - 03/25/2012
I manage my calendar via Outlook Express. There are some events which occurs every month like week end review with sales persons, finalizing weekly tasks at every start of week. Is there any option of reoccurence the events?
Re Occurrence of Meeting Schedule
You are trying to create recurring appointments using Outlook Express. Here’s how it is done in Microsoft Outlook 2007. Try adapting it on your Outlook Express.
In the Navigation pane, click Calendar.
Select Actions then New Recurring Appointment.
In the Appointment Time section, click on Start text box and then enter the start time.
To select how often the event or appointment will repeat, click Daily, Weekly, Monthly, Yearly found on the left side of the Recurrence Pattern section.
Choose on the right side of the Recurrence Pattern section how often the appointment or event will occur.
In the Start box under Range of Recurrence section, enter the first occurrence of the event or appointment.
Select when the event or appointment will stop. You can choose No End Date, End After, or End By.
Click OK.
Click on the Subject box and then enter the subject.
Click on the Location box and then enter the location.
Click Save and then Close.
