Read About Png To Jpg Batch Converter In Brief.
Hi all,
I have a query regarding png to jpg batch converter in Linux. I have tried the conversion online on many sites, but failed. Is there any software available or it can be run manually?
I am using Ubuntu
Answered By 20 points N/A #299297
You can attempt to install Image Magick for this purpose.
I don’t know about the actual usage, but I am sure you can do almost anything related to an image with this software!
For example:
And it will keep the original image and create the new image. As for a batch file, I feel that you require using the tool Mogrify. Remember that this over writes your old image.
The command is as below:
