Read About Putty For Windows 7 64 Bit In Brief.
I want to ask about the putty for windows 7 64 bit in detail. Can someone explain about the same?
If yes, please share your information with me.
PuTTY is an implementation of SSH as well as Telnet for Windows and Unix operating systems, along with a terminal emulator. Writing and maintenance of this are by Simon Tatham.
You are now able to get 64-bit Windows builds of PuTTY, along with the 32-bit ones.
Right now, the 64-bit builds run as far as I know, but they haven’t had that testing as the oneswith 32-bit. Hence, you must consider the 32-bit builds wherever possible. However, if you have some reason to use a 64-bit build or if you just feel like executing the new builds to try, then let me know in case of any trouble.
