Read About Realtek Hd Audio Windows 8 In Detail.
I want to know about realtek hd audio windows 8. If anyone knows about the same, please share your knowledge on the topic.
Thank you.
Thank you.
To install the audio tool on your Windows 8, just follow these steps:
Step 1. First, start the setup.exe software to begin the installation.
Step 2. Then, click Next to continue the process. Remember if the screen resolution is less than 1024*768, then press Yes to proceed the installation. If the message “Windows can’t verify the publisher of this driver” appears on the screen, then select “Install this driver anyway.”
Step 3. Choose to restart the system and press Finish to finally end the installation.
