Read About Square Root Symbol In Word In Detail.
Hi everyone,
I wish to ask about square root symbol in word in brief. If anybody is having any clue regarding this, then please explain it in reply.
Thank you in advance.
Hi everyone,
In Microsoft Word 2016
Like any other symbol such as Copyright (©), Trademark (™), and Registered (®), inserting the square root symbol in Microsoft Office Word is easy. It can be done from the menus. To insert the square root symbol, in Microsoft Office Word, select the “Insert” tab then under “Symbols” section select “Symbol” then click “More Symbols” at the bottom.
On the next screen, set “Font” to “(normal text)” then scroll down the list. At the bottom, look for the square root symbol, select it, and then click “Insert” then close the dialog. The square root symbol (√) should now be inserted in your document.
