Read About Windows 8.1 Offline Update In Detail.
I just wish to know if anyone can tell me about windows 8.1 offline update. I would be glad to know that someone has an answer to my question.
Please help.
Please help.
Windows 8.1 Update is a combination of security updates and critical updates. You should install Windows 8.1 Update to make sure that your PC can continue to receive future Updates, including security updates. For a complete listing of the problems that are present in this update, check the associated Microsoft Knowledge Base article for some extra information. After you install this product, you need to restart your device.
Supported Operating System
Windows 8.1
Codenamed “Blue,” Windows 8.1 is an upgrade to the Microsoft Windows 8 operating system. Compared to Windows XP Service Pack 3, Windows Vista Service Pack 2, and Windows 7 Service Pack 1 which are the latest Service Packs for these operating systems, Windows 8.1 is also a Service Pack for Windows 8.
Windows 8.1 was released to manufacturing on August 27, 2013 and for general availability on October 17, 2013, just almost a year after the retail release of Windows 8. You can only upgrade to Windows 8.1 for free if you have the retail version of Microsoft Windows 8 or Microsoft Windows RT. If you have Windows 8, upgrading to Windows 8.1 is a must to have a continued support.
But unlike the previous Service Packs that can be downloaded from Windows Update, with Windows 8.1 it is not the same. It has to be downloaded separately. If you have Microsoft Windows 8, download the Windows 8.1 Disc Image (ISO) and upgrade your operating system.
Notifications
