Read About Windows 8 Outlook Settings In Detail.
I just wish to know if anyone can tell me about windows 8 outlook settings. I would be glad to know that someone has an answer to my question.
Please help.
Please help.
If you want to use Microsoft Office Outlook as email client and send and receive email messages, you need to get your email account’s IMAP or POP settings. You won’t be able to use Microsoft Office Outlook until you have your mail configurations. You can get the correct settings from your mail service provider.
In Microsoft Office Outlook, there are two account types you can use: IMAP and POP. For Gmail, here are the correct IMAP and POP settings. For IMAP settings:
For POP settings:
In Gmail, you have to enable IMAP or POP first on your Gmail account before you can use an email client like Microsoft Office Outlook. To enable IMAP or POP on your email account, open your web browser and log in to your Gmail account. Next, click the gear icon on the upper right corner of the screen then select “Settings.”
In “Settings” screen, go to “Forwarding and POP/IMAP” tab then enable the appropriate settings. If you want to use IMAP, in “IMAP Access,” select “Enable IMAP” then click “Save Changes” at the bottom. If you want to use POP, in “POP Download,” select “Enable POP for all mail” then click “Save Changes.” Now, in Microsoft Office Outlook, go to “Tools” then “Accounts.”
In “Internet Accounts” window, go to “Mail” tab then click “Add” and select “Mail.” In “Internet Connection Wizard” window, in “Display name,” enter your full name or the name you want to appear in your email messages then click “Next.” On the next screen, in “E-mail address,” enter your Gmail email address then click “Next.”
On the next screen, select a server from the dropdown list (POP3, IMAP, or HTTP). If you want to setup a POP account, select POP3. If you want an IMAP account, select “IMAP.” After this, enter the details of the server from the list I created above then click “Next.” On the next screen, in “Account name,” enter your Gmail email address then your Gmail password in “Password.”
Click “Next” then “Finish.” After this, select “imap.gmail.com” item in “Mail” tab then click “Properties.” Next, go to “Servers” tab then under “Outgoing Mail Server” section, check “My server requires authentication” then click “Settings.” On the next screen, make sure “Use same settings as my incoming mail server” is selected or checked then click “OK.”
Next, go to “Advanced” tab then set the correct port numbers and protocols. When you are finished, click “OK” and that’s it. Test your new account by sending a new email message to your own email address. If you receive an error, check the configurations above.
