Read How To Solve Playstation Error 80028e02/8002A203 In Brief.
Hi all,
I am using PS3, but I am worried about the playstation error 80028e02/8002A203 as it keeps popping on the screen whenever I turn it on.
Can someone help me in resolving this issue?
Thank you.
Answered By 10 points N/A #299222
The code 80028E02 error implies that the connection to the server is over.
It can occur when connecting to an ISP that needs the user to log in with a username and a password.
To fix this, just open the internet browser on your device and check if there a message from your Internet Service Provider or a login page (then perform those instructions). It is not in the link to the PlayStation login, so you would require calling the ISP.
I hope this helps.
