I owned Nokia x6 and I want to read my PDF file on my mobile phone through acrobat reader. How can I read my PDF file on my Nokia x6 using acrobat reader correctly? I am trying to upload my saved file from my desktop into my mobile phone but it doesn't work.
Reading file on nokia x6 through acrobat reader
Hi Grant,
You can use the Nokia Store. This is the in built application By Nokia.
You can Follow the following step and you will download the app:
1. Open menu > Nokia Store
2. Go to search option inside Nokia store.
3. Put "Adobe PDF" in search & Press Search.
4. Find "Adobe PDF" in search result, download & Install.
Now you are able to see the PDF files.
Thanks!
You can easily found your solution from the Nokia Ovi stores, you can visit there and manually process with the root of you trouble and can easily found the solution from there, you can also search in the search engines to get your desired solution.
Hope you can found your desired solution in quickest possible time.
