My brother gave me his old Samsung galaxy ace mobile phone. I am new to the android OS. I am always reading PDF files for my work as a lecturer. Can anyone help me find a free software to read PDF files that i can download. Software must be small but reliable and also easy to use.
Reading PDF files with Android Smartphone
If you need a PDF reader to use on your Android phone, try using Foxit MobilePDF for Android. The latest version at the moment requires Android 4.1 Jelly Bean or higher. This Android version of Foxit Reader allows you to view, annotate, and protect PDF files directly on your Android device. It also supports 12 languages. Foxit MobilePDF for Android offers in-app purchases.
For iOS users, you can use Foxit MobilePDF for iOS. It supports iPhone, iPad, and iPod touch and requires iOS 8.0 or higher. If you prefer using the PDF reader from Adobe, go to Adobe Acrobat Reader DC. To download the Android version of Adobe Acrobat Reader, in “Step 1,” select “Android” for the operating system then select your preferred language in “Step 2.”
In “Step 3,” select the version of the Adobe Acrobat Reader according to your Android version. Adobe Acrobat Reader is available from Android 2.2 Froyo until Android 4.1 Jelly Bean and higher.
