Real player to quicktime video conversion
Asked By 7060 points N/A Posted on -
I have a bunch of real player video that I need to convert to QuickTime format.
What is the simplest way to convert my videos?
Can I automate the task – say if I want to convert a whole folder of videos?
Best Answer by kumar59
Answered By 0 points N/A #84650
The simplest way to convert real player video to QuickTime format is to use a converter.
I suggest you to download and use A-Z RealPlayer Video Converter 6.45 software at this site.
This software has an easy to use interface and can be simply used and accessed by the fewer experimented PC users out there.
Best regards,
Heather marie
Answered By 0 points N/A #84652
1. Go to www.media-convert.com from your web browser like chrome,mozilla firefox,internet explorer.
2. Click choose file and locate .rm file on your computer and click ok.
3. Select rm or real video as input extension from extension list.
4. Select mov or quick time movie as output extension then click ok
5. After some time file converts and pop opens to download link of file
otherwise go to www.mediaconverter.org then upload rm file by clicking upload file on home page
1. Then select mov as output extension then click start to begin conversion
2. Click on the link appears after conversion to download file into hard disk
