Real-time monitoring software for PCs
Is there a software I can use to monitor webpage visits from each computer in my company real-time? I have about 30 computers all in all. I need to track their actions and see what they do on the Internet all day. They all use a Mac and they are all connected to a wireless network. Thanks in advance for your help.
Answered By 0 points N/A #199932
Looking for a method to monitor webpage visits on other company computers is going to leave you with very scarce results because of the thin list of options that you can use. Aside from any software that promises to do what you need in real-time, especially for Macintosh users, the list narrows down to one very good monitoring software that you can use in the company:
Wireshark is an all in one monitoring software that is able to record in real-time what data you need collected. Whatever the user does, whatever he types, and whatever website he visits will be recorded and transmitted to the administrator.
This program has a very wide feature list, from which are worth mentioning:
– Live capture and offline analysis
-VoIP analysis
– It can read live data from the Ethernet, IEEE 802.11, ATM, Bluetooth, USB, and many others
– Decryption for a wide array of protocols including IPsec, WEP, WPA/WPA2 and even Kerberos, and list goes on.
The best part is that it can be installed on a Mac without a problem. It supports any OS X from 10.6 to later distributions.
