Davis Avon
20 points
Posted on - 08/25/2012
I'm having an error when I try to record using my realplayer, whenever I press the record button this error always pops up and I still have about 100gb space on my drive.
Recording Error
Not enough resources to continue recording.
Realplayer showing error when recording
Hello Davis,
You will need to check the free space that you have on the system for the issue you are getting may be as a result of low disk space and therefore the files you are trying to record cannot be stored successfully.
Clear up more space on the partition that you are saving the recorded the files and see if that resolves the issue.
Otherwise, try the following workaround:
You will need to go to RealPlayer Preferences.
After that you will set the "Download" option to appear in three ways.
Set it to appear in either in the toolbar, on a mouse over, or with a right click.
Hope that helps.
Carl
